P4 1.8A / P4T-E Benchmark Results
Toast
Greetings,
I have completed the first phase of benchmarking my P4 1.8A on an Asus P4T-E. The effort was constrained to a maximum of 133FSB with a constant vCore of 1.525V across all frequencies. The attached graphs illustrate the results, and provide extrapolations to much higher frequencies. Based on the low voltage need at 133FSB, the cpu appears to have significant potential to be driven much further.
All the benchmark results were obtained through Sandra 2002.
Toast
The following graphs have been updated with the additional information that was graciously provided by rekless and antmanmike. Thanks for the data !
Toast
T
Toast
Sandra 2002 CPU Performance Benchamarks
AntmanMike
Chicago.
Can u test it 2600+ mhz? I hear that at those speeds, the speed starts to lower, so technically, it should sooner or later turn into a parabola, or something similar (maybe just a curve?). Currently it looks like a linear equation, but i dont think that it is infinitely linear.
T
Toast
If the Pentium 4 was capable of operating at ever increasing frequencies, the benchmarks would continue to scale linearly with core frequency. While the Sandra benchmarks appear to be independent responses, other benchmarks are highly coupled between ALU, FPU, and MEM performance with hidden boundary constraints.
Toast
T
Toast
If anyone has data beyond 2.4GHz with the same setup (1.8A/P4T-E), let me know so that I can update the benchmark graph.
Toast
Teken
The Bad Lands
Help...
Toast,
Thank you for the supplied link... I unzipped the Sandra file and have 19 files... I opened the obvious set-up exe. and install files with no success... Can you take a few moments and tell me what specific file needs to be opened to execute this program to run and operate...
Regards
Teken<---Who is a little lost right now... :(
T
Toast
Teken,
It sounds like you downloaded the right collections. Once you have extracted all of the files into a folder, run the SETUP.EXE application, and follow the instructions. Make sure you view all the file details to verify the selected file type is an application.
You may want to verify that the version you downloaded is intended for you operating system and configuration.
Toast
T
Toast
thanks dude
Rekless,
Thank you very much for the extra data. Ultimately, I am hoping to generate a simmilar collection for most of the Northwoods. Given the number of overclockers on this forum, there should be ample information to generate the contours.
Thanks,
Toast
rekless
San Diego, CA
CORRECTION!
I made a mistake there Toast. Those values were for 2484MHz.
2566MHz: 10032/ 12213
When I did these benchmarks I must have overwritten one of the files cause I no longer have the scrn shot of multi media @ 2592.
I have since reduced my core voltage and FSB. So I cannot run another one @ 144 at this time. But I bet you could tell me what it should be.
Sorry for that screwup.
rek :)
T
Toast
rek,
No problem. I will update the values during the next edit.
Toast
chop
Dallas, TX.
rekless said:
Mulitmedia:
2592MHz: 9747/11817
and here is 2664MHz:
Hey Reckless, how do you attach your results like that? Do you need the full version of Sisoft to attach the screenshot? Thanks.
rekless
San Diego, CA
I just use the prnt scrn function (windows) and then edit in a paint proggy. Has nothing to do with sandra.
This message board has the option of adding an image file to your message.
Thats it, nothing special.
rek :)
