- Nov 30, 2005
I just bought a Silverstone TJ06 case, and my power connectors won't reach to the mobo. I found an extension for the main connector at Fry's, but not for the square 4-pin P4 power connector. They did have a connector that adapts from a regular molex connector like you use on a hard drive or cd-rom, it just has wires coming out of two of the 4 pins on the wide hard drive end, and then it goes to a p4 connector on the other end. So I assume that you can just simply plug it into any of the connectors on the psu that are handy and then plug the other end into the mobo.
Can someone please verify if this is the right thing to do or should I special order an extention cable on the internet? Also I'm wondering if it matters to spread the load on the molex wires out, or can you just use one wire and put lots of Y extenders on it?
On a side note, one of the fans in my psu went out and when I took it apart to mess with it I noticed that a couple of the medium sized caps inside were leaking (brown crusty stuff on top). Is it recommended to junk the psu in this case or will it still function ok in general?
