Asus Maximus II Formula P45 Chipset
This board is going to be pretty expensive at launch (~300$), but the features on it make it better than an X48.
It has a few new features that make it really cool.
Speeding HDD –
If you install two newly formatted drives into the Silicon Image 5723 SATA ports, the system will automatically stripe the drives (RAID 0) without the need for drivers. A switch in the BIOS or the enclosed software utility allows for RAID 1 operation. The beauty of this setup is that the SI 5723 performs all array calculations in hardware and does not require special OS driver support. The OS sees the arrays as standard ATA devices. Performance is on par with the ICH10R in our testing."
Automatic Raid0 direct hardware
CPU Level Up – This feature is still being tuned in the BIOS. It is automatic overclocking of the CPU at a basic level. The interesting feature is that you choose a processor speed to overclock to in the BIOS and it will adjust all required BIOS setting to reach that setting provided the processor and other components in the board are capable of overclocking. Proper cooling is required for the more extreme overclocks. This should simplify overclocking for the beginner who does not understand FSB and Memory ratios but does understand processor speed.
It also provides a quick sanity check for the intermediate user who does not want to spend a lot of time changing a variety of BIOS settings before figuring out the processor limits. Our Q6600 sample was running at 3GHz in about 15 seconds when using this system. Granted, more advanced users will want to tune the BIOS, but for beginners it is an easy to understand system for overclocking."
This literally makes overclocking so easy anyone can do it. You basically tell what speed you want and it does everything for you
This board also has 2 bios's, so if you mess one up / bad flash, you still have a backup to go to.
It also has a new and improved onboard audio codec that supports EAX 4.0.
600 FSB's with this chipset pls
Source -
http://www.anandtech.com/weblog/showpost.aspx?i=455
