- Nov 16, 2001
Ive got a bit of a problem with my board and how its clocking the ram.
If I add pc100 at a fsb of 120 and a fsb:mem ratio of 1:1, I get a mem speed in cpuid of 160mhz.
If I add pc133 I get the same.
basically its giving a ratio of fsb:mem of 3:4.
The bios specifically says for the ratio auto,1:1 or 3:4 but I always get 3:4.
As most of my ram (640mbs) is pc100 I use that and not the 128mbs of pc133.
Ive updated my bios today, this didnt help.
Has anyone got any ideas about why I dont get the 1:1 ratio I select?
Also, I set my fsb to 126 (cpu=2520mhz from 2ghz) with pc100 (@168) and it works fine. Its completed the tests I give it anyway.
But it wont reach a fsb of 127. Well it does but it aint stable when benchmarking. Now Im persuming its my ram but when I add the pc133 it still isnt stable. The ram timing settings are set to the slowest and the voltages are cpu=1.625 and mem=3.5v.
Is there a way ( apart from setting my ratio to 1:1 )to make this more stable? For some reason my cpu dont like 1.65v though the temp is only 50ish at full load.
Im really confused about this memory thing. 168mhz stable as a rock with pc100 seems a little long in the tooth, but thats what cpuid says, not me!!
Cheers for any help guys
