here they are, CPU and the Memory test.
NOTE< at the moment I am clocking at 3.73, new test later.
SiSoftware Sandra
Test Status
NUMA Support : No
SMP Test : No
Total Test Threads : 2
SMT Test : Yes
Number of Test SMT (per CPU) : 2
Dynamic MP/MT Load Balance : No
Processor Affinity : No
Number of Runs : 64000 / 640
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.20GHz
Speed : 3.63GHz
Performance Rating : PR4831 (estimated)
Type : Standard
L2 On-board Cache : 512kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
Chipset 1
Model : ASUSTeK Computer Inc 82875P Memory Controller Hub
Front Side Bus Speed : 4x 227MHz (908MHz data rate)
Features
SSE2 Technology : Yes
SSE3 Technology : No
HTT - Hyper-Threading Technology : Yes
Performance Tips
Notice 5008 : To change benchmarks, click Options.
Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.
Notice 5006 : Only compare the results with ones obtained using the same version!
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Test Status
NUMA Support : No
SMP Test : No
SMT Test : Yes
Processor
Speed : 3.63GHz
Type : Standard
Chipset 1
Features
SiSoftware Sandra
Int Buffered iSSE2 (Integer STREAM) Results Breakdown
Assignment : 4058MB/s
Scaling : 4006MB/s
Addition : 4005MB/s
Triad : 3992MB/s
Data Item Size : 16-bytes
Buffering Used : Yes
Offset Displacement Used : Yes
Bandwidth Efficiency : 83% (estimated)
Float Buffered iSSE2 (Float STREAM) Results Breakdown
Assignment : 4027MB/s
Scaling : 4031MB/s
Addition : 3996MB/s
Triad : 3993MB/s
Bandwidth Efficiency : 82% (estimated)
Test Status
Memory Used by Test : 511MB
NUMA Support : No
SMP Test : No
Total Test Threads : 1
SMT Test : Yes
Chipset 1
Front Side Bus Speed : 4x 228MHz (912MHz data rate)
Width : 64-bit
Maximum Bus Bandwidth : 7296MB/s (estimated)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR-SDRAM 2.5-4-4-7CL 1CMD
Bank 1 : 512MB DDR-SDRAM 2.5-4-4-7CL 1CMD
Channels : 2
Speed : 2x 152MHz (304MHz data rate)
Width : 64-bit
Performance Acceleration Technology : Yes
Maximum Memory Bus Bandwidth : 4864MB/s (estimated)
Features
MMX Technology : Yes
SSE Technology : Yes
Performance Tips
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. SiSoftware Sandra
Scaling : 4006MB/s
Addition : 4005MB/s
Triad : 3992MB/s
Scaling : 4031MB/s
Addition : 3996MB/s
Triad : 3993MB/s
Test Status
NUMA Support : No
SMP Test : No
SMT Test : Yes
Chipset 1
Width : 64-bit
Channels : 2
Width : 64-bit
Features
