- Oct 26, 2002
- Northern Virginia
I just upgraded from a 2.4C to a 3.2e SL7E5 on my P4C800-E Deluxe (droop modded). When I went into the 1019 BIOS to set the voltage, I noticed that the minimum voltage option was 1.37v. The voltage spec on the Intel web site says the range for the CPU is 1.25-1.4 volts.
Is this a normal/correct minimum for this BIOS on my MB? I would think that I would be able to get the lower voltage options.
