P4C800 users - easy overclock with..
Designer
all users of P4C800 (E,C,r,m,...even XYZ) can overclock them board cpu mem all when:
Try this small software to add more speed to your PC at this link:
http://www.ocforums.com/attachment.php?attachmentid=31759
Don't try to reach to the end of the slide unless if you don't like your PC at that point give me your system and I will kick *** it
I hope you to be careful when u use the max speed you try to reach to!!!!!!!
D
Designer
oooooh
from 82 viewers
No body said even thanks
or it's bad or ,
Ok thanks Designer
Goldstandard
California
Here is a tip, if you put up an attachment, make sure it works before you get all upset and resentful, because it doesn't. Also, if you decide to use such poor grammar, you make yourself out to be an idiot. Keep this in mind next time you decide to start a thread.
D
Designer
sorry guys.. :D :bang head
It's not my falls
I test downloading after i attach it in attachment manager & it WAS working, sure, then I post it, but I dont know what happen to that link ? :confused:
So no problem get it from the sorce
click HERE
But please next time if I forget checking (always happen) some body tell me that link is died :argue: :argue:
sOrRy aGaIn
:cool:
