Hi everyone. While I am not new to computers, I am new to building your own and overclocking. I see that some of you here have hardware about the same as mine and I see the stats you post and wonder what it is that I am doing wrong/or not doing because I can't get mine even close to what you are getting.
I have an Asus P4C800 with a P4 3.0 and 1 gig of Corsair CMX512 3200LL DDR Sdram that I just put together as my first project in doing it yourself. I am using air cooling at this time, but am willing to invest in a water system if needed to obtain the results I would like to have. I have 3 80mm intake fans (1 blowing on the cpu and heat sink at the back, and 2 on the side, 1 blowing on the graphics card and 1 blowing on a hard drive. I have a 4 inch blow hole on the top with a 120mm blowing exhaust.) I have a tt 7+ copper heatsink and fan on the processor. The idle temps run at 32-33C and the loaded temps hold at 46-49C.
The best I have been able to get this system up to is 3.42 Ghz and still be stable. In other words it passes the Prime95 torture test and the Sandra burn in test. The settings I changed to get here were the cpu freq changed to 228 and vcore to 1.60 and I set the memory to 2.5-2-2-5-4. This shows a Cpuz reading of 3.419, a FSB of 228, and 912 bus. Trying for anything more causes it to fail both Prime95 and Sandra even raising the vcore to 1.725v didn't help, only raising the temp to 53C loaded.
I would love to get this system up to at least 3.5 or 3.6 and be stable. Could one of you, or all of you, slap me up side the head and tell me what it is I need to do to do this. Thanks so much for any help you can give.
jm
