P4P800 E-DELUXE ratio????
grifter510
Hi there guys I just wonder were can I find the ratio settings on ASUS P4P800 E-DELUXE mobo all I can see are whole numbers e.g. 14,15,16... do you have any idea upon what do the numbers represent??? :confused:
G
grifter510
I'm trying to locate the ration of cpu to ram 5:4 thingy but I can't seen to find it I'm planning to overclock my 2.8E prescott using the 5:4 ratio but can't find it any idea upon were to look at by the way I'm usis a p4p800 e deluxe mobo
ciku
i think under configuration > jumper free settings... or if not, the one below...
Orka
as meionm mentioned, but only in case that the CPU installed has 200MHZ FSB.
in case that FSB is 133MHz, 266MHz under Memory settings will actulaly say 1/1.
in case of OC memory frequency does not appear different in the BIOS. it refers only to the standart FSB of the CPU installed.
