P4PE + Alpha PAL8942, does it fit?
Calavera
Pasadena, CA
The Alpha PAL8942 requires 4 mounting holes on the motherboard. I don't see four holes on my P4PE.
Or are those white wax-like circles at each corner of the CPU HSF bracket area removeable?
Bottom line, does the Alpha 8942 fit in the P4PE? Does it come in contact with any resistors..etc?
vbhard
Sydney, Australia
You have to remove the bracket to see 4 holes.
Yes it does fit without touching the capacitors. :)
eva2000
Brisbane, Australia
Calavera said:
Hey thanx!
Is removing the bracket hard?
use a flat head screwdriver and pry under the white tabs and lift it enough so you can pull them out with your fingers... not hard to do
i have 3 x alpha 8942s :)
tstrike
is the alpha 8942 a good heatsink?
i heard swiftech si the best?
what about the coolermaster heatpipe?
