- Sep 29, 2002
- Sacramento
I just got this board up and running, and I am getting an error message from the probe with a niosey beep beep beep of it being below the threshold..... it is the voltage moniter for the one above the vcore, it is supposed to be 3.34 and it is going between 2.80 and 3.04, how do I raise this voltage?? Is it a problem, the temps are o.k., , but this has me worried, as ASUS will not be back until Monday....
UPDATE, the board has crashed to reboot a couple of times in the past halkf hour, it is probably because I did not put in the drivers for the temporary vid card I have in here...... the drivers are loaded now, and we shall see if that was the cause of the crashes, but I STILLL need some advice on maybe why it has some voltage issues, IS MY NEW MOTHERBOARD IN DANGER? HOW DO I KNOW PLEASE???
I am not upset, just worried, this is a big investment that I cannot replace any time fast, and it is part of a business in it also, so any advice is helpful.
UPDATE>>
I FOUND OUT PART OF THE PROBLEM WAS LOOSE MEMORY> THAT TOOK CARE OF IT, SO SIMPLE AND YET SO MUCH "FUN" TRYING TO FIGURE IT OUT. THANK YOU ALL FOR YOUR HELP , AND GUIDANCE THROUGH ALL THIS.
UPDATE>>
