- Jan 7, 2005
- Bowling Green ,KY
Ok went threw some old comps and parts from a friend thought had all celerons yet there was a year old dell sitting in the pile that had a sticker said hit by lightining
well anyways is a P4 2.2 Northwood (i have a 2.4 NW in wifes comp so testing was easy ) i figured for free not bad
so had to get some ram and a fan and a mobo
went with a AC supersilent ( fan was broke when opend and cant return so took a 4" case fan and zip tied the corners on with the air blowing away from heatsink not sure how well that is going to work )
ram from the comps laying around all pc2700 2 sticks 256 each total 512 ( ill get more later if needed )
had to get a vid card decided to go a lil $$ and got a XFX 6800
had to get a mobo and only one in town for a 478 with agp P4S800d-X
had xtra 500 watt psu already tested
and xtra case
ok installed XP on a 40g 7200 booted comp says no cpu fan well i know fan is turning after boot and all setups says 0 speen on case fans and the modded cpu fan yes all 3 have 3 wires and posted speeds of 2000 or more on other system using asus probe says no speed and just beeps
on boot up it stops till you press f1 ( i turned that off )
i cant find anything about it in other forums yet thought i read about it needing a bios update long time ago ( maby diff mobo cant remimber )
any ideas ???
also what should i set the temp to for the cpu the mobo and the 6800 gpu
after that what is good program to run for heat checking only ?
and xtra case
any ideas ???
