- Mar 21, 2011
Hello denizens of overclockers.com!
I've often lurked here and now I must come to you for help. After getting excellent advice from the folks over at www.overclock.net, I have narrowed my problem down to RAM.
I have got a solid overclock with my I5 750 at 4.0 GHZ, however, when I have more than 2 sticks of RAM in my system, the computer will constantly reboot before it even gets to BIOS.
I have ruled out the RAM sticks or slots being bad because if I do not overclock the CPU at all, all 4 2-GB sticks of RAM work just fine. Another thing to note is that all 8 GB of ram are the exact same brand and model (Corsair XMS). Lastly, I recently had all of this working fine, even with 4 sticks of RAM, however, I unfortunately had to reset CMOS for an unrelated reason and did not remember exactly how I had my Freq/Mem settings. Shame on me!
So, what do you guys think? Here are some specs from BIOS to help with the diagnosis:
DRAM frequency: 2:8 (1600mhz)
Timings: 9-9-9-24
CAS: (9)
MCH Strap: 1600MHZ
Vcore: 1.35
DIMM Voltage: 1.65
CPU VTT: 1.25
PCH: 1.050
CPU PLL: 1.8
Now, keep in mind, this works great with my 2 sticks of DDR3. The problem arises when I put the other 2 stick of 2GB each into the system. After I do that the system does not post and goes into an infinite loop. I've tried upping the VTT to 1.35 and even 1.4 to no effect. I've also tried uping the PLL to 1.9 and the PCH to 1.125, also, no help.
Thank you all in advance!
Timings: 9-9-9-24
CAS: (9)
MCH Strap: 1600MHZ
Vcore: 1.35
DIMM Voltage: 1.65
CPU VTT: 1.25
PCH: 1.050
CPU PLL: 1.8
