Hello all,
It is a great pleasure to have found this forum with members who have a vast knowledge.
Recently I was give a P5Q MB with a Q9400 cpu. Since I had some other parts laying around, I decided to put all of these together and have a kind pf back up PC.
However, I am having trouble with two problems:
The PC starts only after I clear MB cache using the jumper. Everything works OK after that (except the other problem mentioned below). This is till the next boot. On the next boot, the fans start spinning but the OS does not show at all on the screen till I clear the cache again.
The other issue has to do with the CPU fan speed. It runs at its max speed (i think) and there are no other programs running in the same time. I checked the CPU temps at they seem to be in their lowest.
Would you be able to say if I am doing sth not right?
Any help will be very appreciated.
Thank you
Thank you
