First the memory adjustment. When it stabilizes then I try to raise the FSB again before I go for voltage increases.
Deleted all the failures to make it more sequential and usable for any needing to reference.
Watch this space for further updates.
______________________________________________
Couldn't get anywhere so I am going back to the last known settings that worked reasonably well and making only one change at a time so I can Identify the issue.
- FSB: 300
- RAM: 600
- PCI Frequency: 100
- PCI Clock Sync. Mode: 33.33MHz
- RAM Voltage: Auto
- RAM Timing SPD: Enabled (I had this previously at 5-5-5-15-5, checked Corsair site and it says this memory tested at 800MHz, 5-5-5-12-T1 and 1.9v. This is for 2 matched CM2X1024-6400 modules. What is T1?)
- CPU Core Voltage: 1.3500V (Is it normal for this voltage to vary during stressing from as low as 1.31 to 1.34?)
- FSB Termination Voltage: Auto
- MCH Chipset Voltage: Auto
- ICH Chipset Voltage: Auto
- Mobo Temp: 43 (looked at Asus site and it says normal temps 40-60. Turned of the big fan off to get it up to normal temps)
Running Orthos so far for 45 minutes. Considering all is reasonably well an I am beyond the magic 30 minutes where it was failing before I will try playing with the memory as per above.
Looks like it was the wrong memory settings. Now setting it up exactly as per manufacturer recommendation.
- FSB: 300
- RAM: 800MHz
- RAM Voltage: 1.9v
- RAM Timing: 5-5-5-12-5 (Last 5 instead of "T1" is a guess as I don't know what "T1" means. Anyone?)
- CPU Temp: 45-51 (Isn't this a huge deviation range?)
- Mobo Temp: 43 consistent
Running Orthos so far for 45 minutes and considering that all is well I will next up the FSB again.
Prior to the below run I did another one with eaxctly the same setting as below except with FSB at 310 and RAM at 775. No issues so bumped up to below by just upping the FSB.
- FSB: 320
- RAM: 800MHz
- RAM Voltage: 1.9v
- CPU Core Voltage: 1.3750V (Is it normal for this voltage to vary significantly during stressing or during normal operation?)
- FSB Termination Voltage: 1.2V
- MCH Chipset Voltage: 1.55V
- CPU Temp: 48-54 (Isn't this a huge deviation range?)
Running Orthos so far for 45 minutes and all is well. Found out that Orthos likes to fail during the first 35 minutes. If it gets past that point I start feeling safe. Am I correct?
After a couple longer atempts to run Orthos at this speed I had to up the Vcore to 1.4v to keep it absolutely stable.
- FSB: 325
- RAM: 817MHz
- RAM Voltage: 1.9v
- Vcore: 1.4000v (What is the normal range for Vcore during stressing or during normal operation?)
- Vcore actual as reported by sensor: 1.36-1.38v
- FSB Termination Voltage: 1.3v
- MCH Chipset Voltage: 1.55v
- ICH Chipset Voltage: 1.2v
- CPU Temp: 51-59 (wedged a fan right amongst some cable pointing right at the CPU. Seems to have helped by about2-3 degrees on average)
- Mobo Temp: 45 consistent
Ran Orthos for over 10 hours so I am guessing its completely stable.
Cant achieve any significant stability at FSB over 325. Orthos fail times are normaly at about 3, 16, or 22 minutes. Tried many times so far but unable to find the stable setting for FSB 330.
