Oi!
If you decide to contribute your opinion (which i'd indeed like to hear), please know why you say what you say, cause its too easy to confuse a soul who lacks experience on the subject with tips that show confidence but are prehaps a bit hastily put togather. Also, for the same reason id like to point out that im calling for people who got at least a basic understanding and some actual experience on OCing modern systems. Thanks.
Sys:
Corsair TX950 (936 Continuous)
P6X58D-E, BIOS v0602 - 2011/03/24 (Rev/Step: NB: 13/B0, SB: 90/A0)
Core i7 930 (D0) + Scythe Mugen 2 Rev B + Zalman ZM-STG2 TIM
3x 2GB Dominator 1600MHz, 8-8-8-24 (CMP6GX3M3A1600C8)
Win7 Ultimate x64 SP1
Running on stock speeds/volts atm. SpeedStep, C1E, TM Fuction, C-State is off. HT, LLC is on.
On RealTemp 3.60 sys at idle but warmed up, temps are: 51/48/47/44 celsius on core 1/2/3/4 respectively. That is at 1.232V acording to CPU-Z 1.58. After 10mins of Prime95 small FFTs temps are: 69/67/68/65 at 1.240V. How would you feel about these temps?
Dont know how much of value it'll be to anyone but since i see LLC is so controversial, a tiny bit of info i give: LLC disabled my volts are 1.224 idle, 1.192 load. All is the same as above stated.
First thing im lookin for is a volt lacker setup at 3.6GHz.
BCLK 172 x 21, RAM at 8x BCLK, uncore at 2x RAM. Other thing would be 200x21.
What i need firmer knowledge on is quite funnily enough the volt department.
vCore
PLL
QPI/DRAM (VTT)
IOH
IOH PCIE
ICH
ICH PCIE
DRAM Bus (VDIMM)
How low can they be on 3.6GHz and how low on 4.2GHz in your opinion (/experience perhaps)? I know VDIMM will be 1.65 for 4.2GHz since the RAM runs at the exact specs that its certified to, but how much the 3.6GHz setup needs is of particular intrest to me. Very important question would be if - for either setup - the RAM needs a dedicated cooler or not!. How much do you think a 120mm 1200RPM fan hung in front of the sticks, (runnin at how high RPM (if at all)) would count as proper cooling? Also, on 3.6GHz do mention ram latency! How would you manage volts vs timings?
Does the 3.6GHz setup need any differential amplitude or clock skew in your opinions? ..And how much the 4.2GHz needs (if any)?
What do you think about the argument of Load Line Calibration / VDroop?
So Spread Spectrums best left disabled i understand. Any counter arguments?
Is there a program that picks up the value of volt overshoot when the sys is put under load and VDroop is off via LLC?
Is there a program that monitors ram voltage/temp realtime?
Quite alright i'll start testing these setups out myself when i gain some more knowledge on this, but meanwhile id like to keep this channel of info up as well, cause i feel like im gonna introduce some mysterious bugs to the sys and of those i had oh so enough...
Hm.. I'll write back when i remember what i forgot to mention...
Regards
Sys:
vCore
PLL
QPI/DRAM (VTT)
IOH
IOH PCIE
ICH
ICH PCIE
DRAM Bus (VDIMM)
Regards
