Paint to match Antec "metallic gray"?
Derodeo
Alberta, Canada
It's probably a long shot but does anyone know of a spray paint color that comes close to matching what Antec uses on their "performance plus AMG" cases (they call it a metallic gray although I think of it as more a charcoal gray). Thanks.
trdsw20
bay area
Luckily for you there is a ton of different auto paints. I fyou go to a auto supply store you are bound to find at least 6 different greys from one spray paint manufacturer alone.
I did my case in gun mental and this paint runs a bit darker then the cap of the spray paint. Sorry forget the brand
BTW are you painting CDROMS???
sirtoby
Finland
Why not take a drive-bay cover with you and go to some place that sells paint and they'll probably be able to match it for you.
Detho9000
Chicago IL
Bring a side panel to a specialty paint shop or hobby shop (the hobby shop could probably direct you to a specialty paint shop).
They can color match the paint, mix it and can it in an areosol can.
I just hope you got a fat wallet though.
You may also want to try to contact Antec directly. It's a long shot but they may be able to give you the paint mix parts so you can have it mixed or be able to sell you the paint in a spray can.
-D9K
D
Derodeo
Alberta, Canada
Thanks Detho9000 for the Antec contact idea. I have done that and am waiting for a reply. I don't actually have any specialty paint shops around here that I know of although I suspect some car body shops might do this. I was hoping there's some obscure off the shelf spray paint somewhere that comes close to matching.
I have a damaged Antec (right) side panel and also a spare side panel (I use a lot of Antec cases in systems I build). Unfortuately the spare panel is beige so I was hoping to paint it to match. "Metallic gray" is not a common color though...
OrionRU
antec metalic grey ==== Toyota dark grey / metalic grey
Trust me on this, I put my case and my 88' celica near each other, its a perfect match.
D
Derodeo
Alberta, Canada
Hey sounds good. Thanks very much OrionRU. I'll look for automotive paint matching late 80s Toyota dark grey.
