Can I use normal, matte-black spraypaint for this job? I am worried about flammability, and the danger of having hot elecrtical stuff in there surronded by spray-painted walls. Is there a specific paint brand that is better, and more durable/heat resistant?
Will this look O.K. (I can do a good, clean job of it in any case)? I am planning on lighting the interior, so the black paint shouldn't retract from the look too much, and I want it to put more emphasis on the individual components, some of which will be sprayed lightly with red UV reactie paint, for highlights.
And a quick aside about lighting - Do both "UV Cold Cathodes", and "Red Cold Cathodes" put out UV lught? or does only the specific UV cathode make things glow? If I have a tub of each inside of the case, will the purply "UV" Cathode interfere with the Red Cathode's look?
Thanks in advance!
Thanks in advance!
