- Feb 3, 2002
- Lexington, Virginia
i want to paint my case (InWin Q600) a metallic blue (see attached photo)...if it's not metallic, but generally the same blue, thats fine...
at first i was just gonna paint it w/ the vinyl dye, but apparently it is not very durable on metal, so im gonna scrap that idea...
i want it in a metallic blue, but i dont want a mirror shine...
more or less, i want it to look like it has a vinyl-type look to it (like how i may do the drive bays)
so, i guess when it comes down to everything, i want the same, plastic-y finish on everything, so i think im gonna need to use the same type of paint...
how would i go about doing this? i know that i would have to sand the case, put on primer, sand that, put on the paint, etc etc, but i really dont want a mirror finish and i dont want to have a textured finish...i just want straight and flat...
or what i could do is just use the vinyl dye on the metal parts as well, wait a while and then cover it with clear coat, so as to protect the vinyl dye, but im not sure if this works...
anyway, i guess i really didnt ask questions, but please leave suggestions or tips or whatever if you want to
-peter
-peter
