pala7-2
CaptnBackfire87
Little Rock, Arkansas
i just got this protein, it is using the Gromacs core and i got it from server .117, stanfords page says that it is worth 10 points, i mean im not complaining at all, but it seems kinda weird since it is going at around 6 minutes and 15 seconds per frame, and it when it completes a frame on the console it says complelted however many out of 250000 steps, am i mistaken or are most proteins 500000 steps, so i was just wondering if this is really worth 10 points
Ahh so your the first one to get one eh? This was the 18 point protein that nobody got, they must have shrunk it down just for sanity's sake. What are the specs of the box that got it?
I got one too... weird 10 points, I'm doing a frame in 3:29, this can't be right, 10 points in 2hours 54mins? Check it out:
CaptnBackfire87 said:
i'm not gonna complain about being able to 10 points in a few hours but i wonder if stanford put the points down wrong and its worth only like 1 or 2
I think the most likely thing is EMIII is not showing you the correct data..
Try shutting down the client, & downloading the new protein info file from...
http://home.attbi.com/~wxdude1/emsite/download.html
and see if it's different.
EMIII now says it is worth 10 points! Have a look at the log:
[21:59:15] Folding@Home Gromacs Core Version 1.31 (September 25, 2002)
[21:59:15]
[21:59:15] Proj: work/wudata_02
[21:59:15] Looking at optimizations...
[21:59:15] Created dyn
[21:59:15] Files status OK
[21:59:15] Done: 272531 -> 1755549 (decompressed 644.1 percent)
[21:59:15] - Project: 192 (Run 1, Clone 32, Gen 0)
[21:59:15] Writing local files:
[21:59:15] Assembly optimizations on if available.
[21:59:15] Entering M.D.
[21:59:22] Protein: pAla7-2
[21:59:23] Writing local files
[21:59:24] Writing local files
[21:59:24] Completed 0 out of 250000 steps (0%)
[22:02:54] Writing local files
[22:02:54] Completed 2500 out of 250000 steps (1%)
[22:06:23] Writing local files
[22:06:23] Completed 5000 out of 250000 steps (2%)
[22:09:51] Writing local files
[22:09:51] Completed 7500 out of 250000 steps (3%)
[22:13:19] Writing local files
[22:13:19] Completed 10000 out of 250000 steps (4%)
[22:16:46] Writing local files
[22:16:46] Completed 12500 out of 250000 steps (5%)
[22:20:14] Writing local files
[22:20:14] Completed 15000 out of 250000 steps (6%)
[22:23:42] Writing local files
[22:23:42] Completed 17500 out of 250000 steps (7%)
[22:27:10] Writing local files
[22:27:10] Completed 20000 out of 250000 steps (8%)
[22:30:38] Writing local files
[22:30:38] Completed 22500 out of 250000 steps (9%)
[22:34:06] Writing local files
[22:34:06] Completed 25000 out of 250000 steps (10%)
[22:37:34] Writing local files
[22:37:34] Completed 27500 out of 250000 steps (11%)
[22:41:01] Writing local files
[22:41:01] Completed 30000 out of 250000 steps (12%)
[22:44:29] Writing local files
[22:44:29] Completed 32500 out of 250000 steps (13%)
[22:47:57] Writing local files
[22:47:57] Completed 35000 out of 250000 steps (14%)
[22:51:25] Writing local files
[22:51:25] Completed 37500 out of 250000 steps (15%)
[22:54:54] Writing local files
[22:54:54] Completed 40000 out of 250000 steps (16%)
[22:58:22] Writing local files
[22:58:22] Completed 42500 out of 250000 steps (17%)
[23:01:50] Writing local files
[23:01:50] Completed 45000 out of 250000 steps (18%)
[23:05:17] Writing local files
[23:05:17] Completed 47500 out of 250000 steps (19%)
[23:08:45] Writing local files
[23:08:45] Completed 50000 out of 250000 steps (20%)
[23:12:13] Writing local files
[23:12:13] Completed 52500 out of 250000 steps (21%)
[23:15:40] Writing local files
[23:15:40] Completed 55000 out of 250000 steps (22
nope it still looks the same, EMIII is all screwed up on mine and says it is on frame 5, but the console says
[23:08:28] Protein: pAla7-2
[23:08:29] Writing local files
[23:08:29] Completed 26000 out of 250000 steps (10%)
[23:12:13] Completed 27500 out of 250000 steps (11%)
of course it also says frame 5 of 50, so maybe it only goes up one frame for every 2 in the console, like the console is going by 100 but EMIII is going by 50 frames
I just got another ONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Yay!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Gnerma said:
Blast :( If this is a mistake I want as many of these as possible before they fix it :rolleyes:
I WANT ONE!!
I am getting ALL of these right now!!!! Now 3 machines have it!!!! The forth will be finishing a 6 pointer in minutes!!!
I just picked one up on my P4 too. Man I like these. Wonder if I can get em on all 4 of my rigs.:drool:
Ooops, forgot to add. It's a P1.8 @ 2.4 doing about 3:24 per frame.
I also am on my second one and should finish it around 9:00 tonight, maybe i can get a third.:D
And it is definitly a 10 pointer. I just updated my score and it went up ten.:D :D
Got 2 myself.
And YES they are worth 10 pts.
From Stanford.--
....................Atoms---Days----Pts.
192 pAla7-2....11455...11.00....10.00
:beer:
