Hello there,
First time trying to overclock anything here.
Using MSI Afterburner I managed to reach:
Power: 111
Core Clock +150 (1516Mhz)
Memory +500 (4000Mhz)
In fan profile I set the fan to 75% when temperature reaches 75C and 80% when temperature reaches 80C, and of course 100% when temp reaches 85C (I really hope the fan will stay at 75% most time).
Using Unigine Heaven I got:
FPS: 61.0
Score: 1536
Min FPS: 26.4
Max FPS: 128.7
Most of the time when running Heaven or playing, the temp hovers around 75-76C, but that's nothing new, it's about the same temp as non-overclocked using factory fan profile and in all reviews they said it was a hotter card than the rest.
Worked OK, about one hour running Heaven then half hour Rainbow Six and Crysis 3.
Then I had a blank screen after an hour or so of playing Call of Duty 3 (temp was about 78C) and after I turned off the computer from the power button (nothing else worked), Windows 10 Pro refused to load (just blank screening). Tried to system restore it and although at the end of it the message was System Restore failed, it actually worked.
Now all seems fine, had to reinstall Unigine Heaven, ran a couple of benchmarks on default, normal results. Wondering if was connected to the overclock or just an unlucky system crash. My hunch is that the overclock played some part
Quite a scare! An hour before that I ordered Noctua NH-D14 thinking to overclock the CPU too (i5 Skylake 6600k) but now I'm unsure about it.
My values were quite high compared to the reviews I saw for this specific card, no idea if too high though.
What do you guys think? Would appreciate some opinions or advice.
Thank you in advance!
Power: 111
FPS: 61.0
Score: 1536
Min FPS: 26.4
Max FPS: 128.7
