panaflo 120mm L1A's
fiji
berlin
Panasonic Panaflo Axial Fan 120x120x38.5mm, Ball Bearing DC 12V, 6.12W, 2750 RPM, 114.7 CFM, 45.5 dB-A Model: FBA12G12U1A - OEM Bearing Type: Hydro Wave. Connector Type: Plug-In. Aerodynamic blade and venturi design. Locked rotor protection and auto-star funciton. Lower circuit noise by new IC. Easy value-add access to lead wire via plug-in connector on housing
is that what your looking for?
if so http://www.newegg.com/app/viewproduct.asp?DEPA=&submit=Go&description=panaflo
emericanchaos
emericanchaos
Williamsport, PA
no i'm looking for the low speed 30DbA one. only 60CFM. it's for water cooling. if i can't find one for better than 18 i'll buy another stealth cause i already have one.
