- Feb 25, 2004
- N of splat W of Torin
Getting close to done with my Hyte Y70 "Panda" build. I am waiting on a new PSU Gawd knows I don't need one, have an EVGA 1000w and an 850 spares. I liked the new Lian Li Edge tho. So that might be the last part. Also waiting on the new Lian Li Hydroshift AIO. (Plus a couple vinyl Panda decals.
Parts used:
MOBO: Gigabyte Aorus Master X (Thank You sir
RAM: 32Gb or 64 G Skil Tridents. ( If anyone recommends speedier RAM I can give these to another build)
CPU: 12600K (Sorta played it safe till Intel works things out.)
Storage: 4TB M.2 Crucial and a 2TB WD OS M.2. (Tho I may use the 4TB as the OS drive and get another 4TB.)
AIO: Lian Li Hydroshift non RGB fans as I havereverse regular Lian Li infinities as replacements.
Fans: Li Li infinities...3 side reverse pulling air in. 2 140 pulling in at bottom (No reverse available in 140 so I flipped them) 1 140 exhaust in back and 3 on Rad at top for exhaust.
The fans are a little unbalanced , I'll see if it matters.
Almost forgot...
GPU: MSI 2 fan 4070 Ti super. I have only ever bought one white...out of a crap load of GPU's and this goes perfect with the Panda theme.
PSU: Lian LI 1000W Edge.
Extra's: Strimers 600w GPU and the 24 pin. Can't really see the point in the CPU's as you barely see them. I have the GPU strimer prominent as the clip was on this side on the GPU. These can be reverse tho if I take the cables apart, again I'll check air flow. As this shows it off the best as opposed to coming from the top.
Parts used:
Almost forgot...
