"Panda" Hyte Y70 Touch Build.
Very nice work dpanda, if my gf saw that build she would print the pictures and have them put on her undies, she's addicted to pandas :)
Guess you know what and where your next tattoo should go. :unsure: :)
Post magically merged:
Sorry to hear that. What a pita. :(
I've had riser cables crap the bed more often than not... and especially if they are moved around. Fragile things, most of 'em.
IIRC, i reached out to hute and told them what's up and they sent or at worst could buy another.
Yeah I have to get on that. This is also my Plex server and the APU doesn't have enough horsepower to record and serve up the NFL coming and going out over my OTA antenna. My daughter also uses it from her house. Tho I can watch it over the HDHomerun app that only works on a WIfi network.
If you get bored of the panda look, you can always go with strawberry milk ;) They recently added 3 new colors - https://hyte.com/store/y70/cs-hyte-y70-sm
If there are problems with the riser replacement, I can send you one, but I have only the red one from the Y60. You can switch the cover to the white one of yours. It should be the same. I guess HYTE will cover that, but if not, then let me know.
Things are looking up. Received the new Touch screen this morning. Low and behold it is recognized. First tho I bypassed (Which I have done before with no luck) the Strimer cable and the Black MSI 4070 TI Super worked. I needed a GPU to be working or the screen couldn't be used. With both screens working . The Hyte Nexus software recognized the touch screen. I have not gotten the screen to calibrate yet so it recognizes touch but I am confident I'll get that fixed. That is the Nexus software running on the screen. FINALY! :cheers: After this pic I fixed the weather location.
Looking good!!!
Strimer cable...? Are you referring to the pcie riser cable?
The lit Lian Li Strimer cable ext for the 12V High Power (HPWR). It is laying on the bottom unplugged and still lit until I see if it caused an issue with the GPU. It has worked fine but I by passed it. I have another one on the 24 pin. You can see reflected in the fan mirror.
