- Jan 31, 2005
- Mississauga, Ontario
It looks like I wasn't clear enough in my initial post.
I'm going to have 2 loops, each comprised of CPU block, GPU block, res, pump, and 2 radiators. Due to space restrictions, the pump, res, and 2 rads will all be near one another, and the CPU/GPU blocks will be connected. Basically, I'm cooling 2 rack mounted boxes, and there will be a combined 'cooling bay' at the bottom of the rack that the rads, res's, and pumps will be in.
What I'm wondering is whether it'd be better to run the rads in paralell or serial, but in both cases there wouldn't be anything "between" them.
EDIT:
So for a better idea of what I'm dealing with, space wise, here's my setup. The two big boxes in the left rack are getting cooled, the bay at the bottom will house 4 rads, 2 pumps, 2 res's and a dedicated power supply for the water cooling portion.
My plan for the loops was: Pump -> CPU -> GPU -> Rad -> Rad -> Res -> Return to pump.
taht makes no sense though. you'll have the super hot water from the CPU going right into your GPU..
