- Jul 25, 2001
- Rovaniemi, Finland
Ive been thinking about passive water cooling... Now has anyone tried it? Im thinking about two water tanks connected with two lines, other going through the CPU block. Is there any combination of line sizes and block sizes that would make the system run with the mere "warm water rises up" effect? One of the tanks would have to have water level higher than the CPU. How about a combo system with passive water cooling and a silent fan? Has anyone tried this sort of stuff?
Other thing; I have my CPU running at 70C under load with the Titan Majesty M5 (I recall it to be) cooler. Its ORB design. At first the cooler wasnt sittin straight on the CPU as it got up to 90C until I powered down. After some bending I got the latch to hold the cooler straight (I think)... Still, I'd like to improve (alot) from that 70C... And I used the included silicone paste instead of the "sticker" it had on its bottom.
Thanks
Thanks
