_jubei_
Disabled
- Mar 12, 2001
- BROOKLYN, NY
I tried everything Reinstalled windows, changed drivers for video card, reinstalled games, installed Direct x 8, nothing works !!! I also installed cacheman (good program)......
I had before Direct X 8b..... After that my PC started to Freeze up after few minutes of use.. I have 3 partitions C,D,E .... The windows 98se is on C ... I formated the C drive and reinstalled everything. I also have 512 mb PC2100 ram..... Can this be the RAM ??? OR should I format all partitions and Reinstall everything to make sure No corrupted files are left.....
Also I have 3dmax R4..... I don't know where it stores its info, but even when I format C: drive, and than Reinstall 3dmax during the Authorization It KNOWS that 3Dmax was previously installed .. How does it know ??? I thought when you format Windows the Registry is formated as well and all info is lost..... Does anyone have any idea where 3dmax stores this info ?? Maybe Direct X 8b put some corrupted files that I did not delete even when I formatted the C drive and that is causing those problems..................................
