PC has grey screen crash once AMD drivers are installed
Dannerz
First post, so I'll try and get all relevant info in here for you.
GPU - AMD R7 200 Series (Not sure of the specific model)
Desktop
Windows 10 64 bit
Driver installed - Radeon Software Crimson (issue occurs with any version)
Display - BENQ monitor connected via HDMI to GPU
Motherboard - Gigabyte BM150-D3H
CPU - I5-6600
RAM- 32GB DDR4
I have recently built a new computer as my previous one was constantly crashing with a (usually) grey screen with vertical lines.
I initially suspected a dying GPU, so I replaced the card with the above mentioned card. The issue continued, so I suspected it might be another part slowly dying on me.
I eventually grew tired of the constant crashing (95% of the crashes weren't when gaming, but when using an internet browser) and built a new PC.
The only part I used from the old PC was the GPU, as I didn't want to buy a new card with the next gen cards just around the corner.
Alas, the same grey screen crash issue continues, so I am right to assume that the issue is GPU related. I have now uninstalled the AMD drivers and am using generic Windows display drivers, and the issue has ceased, but now I can't play games, which is generally what I want to uss the computer for.
It seems that the problem only occurs whenever I install AMD drivers. When I run the generic drivers, I still have my monitor connected to the GPU and not the mobo.
Is this an issue that is quite common and easy to fix? I would like to be able to continue to use this card as it is quite new still.
Johan45
Could be the power table in the card isn't giving enough voltage at idle. Seen this before in the 200 series. What I did was set a constant voltage to start at windows in MSI AB. Give that a try if the problem goes away you can either live with it, modify the BIOS or return it for another one.
D
Dannerz
What constant voltage would you recommend I set it to?
Edit: MSI AB won't let me change the voltage.
