Hello there, so 2 days ago i bought new parts for my PC because my previous one was not functioning almost at all as it was old as well.
I bought a new:
Mobo : Asus rog strix z390-e gaming
CPU: Intel i7 8700k
RAM: Corsair Vengeance 2666 hz 8x2 kit
Case: Meshify S2 — Fractal Design
Cooler: Corsair Hydro Series H150i Pro
My old parts are
GPU : Asus rog strix 1080 (OC) from the manufacture
PSU: Corsair HX 850i
SSD : Samsung 850 Evo
HDD: 3TB ( forgot which one though )
Now after i got up and running (also to mention that the Case has a Nexus+ PWM fan hub that supports up to nine fans and so i connected the cooler fans there cause it's easier as the mobo doesn't provide many to install onto.)
I overclocked the PC and tried for 5Ghz same settings as another PC i had with the same parts except the case and mobo is z390-f gaming.
The PC was unstable , will get BSOD but then i found my own settings and also lowered the temps as low as possible , around 75 degrees , however there were some spikes at 80 sometimes for 1 second, usually when opening programs, I was concerned why is that happening since the other PC doesn't have such problems as it stays at 5Ghz with very low temps around 70 being the highest.
Either way i left it like that and after i finished all the burn tests I went right straight to game.
I opened 2 heavy games, they worked nicely without lag at all, however after maybe 10 minutes on one of the games, the PC will completely freeze , and that's when i restart and try to lower the settings of my OC like voltage etc etc.
It didn't worked still will freeze.
Then I reset everything and tried again without OC and anything touched.
It did not work , the freeze will happen again and again.
I also left the PC open last on idle and default BIOS just to see if it's going to happen or not, and it was fine this morning until i started gaming.
My apologies for the long text.
Thank you for your time.
I bought a new:
CPU: Intel i7 8700k
My old parts are
