I had a simular issue last month which ended up being ATI catalyst drivers.
Now it is back again with a vengence!( not the same type of crash though).
The System:
a7n8x Asus deluxe MB
xp2700 CPU
9700 pro ATI Video
1.5 gigs Corsair ram.
WD 80 gig hard drive.
Windows XP.
Lots of fans;p
Allright lets start with what happened.
2 nights ago I locked up while I was out at the store. I came back to a frozen PC but no error messages, no BSOD and not rebooted.
I rebooted and continued on gaming awhile, shut down, booted up the next day it ran fine for about 9 hours until it froze again.
Since then it has not lasted over 5 minutes.
It crashes in windows, without any gaming. It even freezes in BIOS after 5-10 minutes. No errors show up in windows error reporting.
Things I have done.
Swapped PSUs. Three times 3 psus. Orginal PSU Thermaltake 480 watt, 2nd PSU unused closet tossed raidmax 420watt PSU , 3rd PSU from other PC that runs more ram, hard drives and a 6800 GT solid a UltraX 600 watt PSU.
PSU always showed stable rails even at time of crash( watching in bios).
Swapped Video Cards. I took out the 9700 pro and put in the 6800 GT and booted into BIOS. Freeze again after a few minutes. I never carried on to try and load windows since it never got past that point.
RAM: I took out my 1.5 gigs of ram stick by stick and waited. Freeze, freeze, freeze. Additionally I took out the corsair xms ram in the other PC and tried it. freeze freeze freeze.
Ok since I could NOT keep windows up enough to complete a discscan or chkdsk I reforrmatted the hard drive using windows CD to boot up.
It froze and locked up 3 times trying to install it.
Wanting to completely rule out a HD I took a old 30 gig HD from closet and tried formatting it. I could never get far enough in windows installation to test it as it froze as well.
CPU temps. They were 36C. Wanting to rule out heat as most crashes soon after booting are typically PSU or heat related, I took off the heatsink and cleaned the CPU and applied new AS5. Temps are now 33C, guess that 2 year old AS3 needed replacing! Still not hot though and well still freezing;/
I disconnected the Floopy Drive and CD drive and booted again. I figured eliminate everything I could right? Still Froze.
So we know the CPU is not overheating at least as far as the monitor shows.
We know the PSU is not the problem.
We know the video card is not the problem.
We know the ram is not the problem.
We know the floppy drive and cd drive is not the problem.
We are pretty sure the hard drive is not the problem as we tried two.
I had taken out the sound card over a year ago so nothing is in any pci slot.
That leaves Monitor, CPU and Motherboard.
Never heard of a LCD causing anything like this but will test it for test sake later to.
Oh and we even tried using the other power strip I run this other pc off of, same freeze.
I have had this motherboard >2 years now and until last month with the driver issue, and now this constant freezing never had a problem/crash since.
I cannot get the system to run long enough at this point to run much if any diagnostic programs, I guess my question is would you all think it is the motherboard or cpu?
The System:
xp2700 CPU
9700 pro ATI Video
Windows XP.
Lots of fans;p
Things I have done.
