PC restarts when loading into Windows 10
Jactus
Built a new gaming PC yesterday, everything was fine, games played fine, until I run Mass Effect and everything started crashing. After the crashes came the reboots when trying to play a game and now the PC will just restart when loading Windows. I can go into BIOS and I can use the PC while in safe mode just fine. Does this mean that it's a drivers problem?
My setup:
MSI z170a gaming pro carbon mobo
MSI GeForce GTX 1070 Gaming X
Intel Core i7-6700K 4.0GZ
16GB of DDR4 RAM
EVGA SuperNova GQ 650W 80+ Gold
Cooler Master Hyper 212 Evo
128gb SSD (with windows installed on it)
1TB HDD
wagex
Chapstick Eating Premium Member
yeah, sounds like a driver issue, did you do a fresh install of windows when you built the pc?
what are temps like on everything cpu and gpu.
J
Jactus
CPU won't go above 35C, as for the GPU, the fans don't even need to start spinning.
I did a clean install of windows and all drivers this morning. But I'm starting to think that I should install a previous version of Nvidia drivers.
trents
Senior Member
I think there are significant driver problems that have developed with recent Windows 10 updates. I have been experiencing crashes like you describe frequently with my customer base, even on brand new computers. It can't all be hardware problems I've decided. Keeping on hand a copy of some Linux live distro that will use entirely different drivers will help sort this out.
J
Jactus
I am now sure that this is entirely the Nvidia drivers problem. I uninstall the drivers on safe mode, and then when i restart the PC it will be fine. That's until I try installing new graphics drivers.
