pc restarts
djwesty72
uk
hi all
ive just bought a asus a7a266-e and a 1700xp cpu and a coolmaster up2 2gig fan
my problem is this my pc works fine a t 11oomhz but when i try 2 turn it up on the bios 2 1400+ my pc just restarts it self
how can i get my pc 2 run faster
thanks 4 any help
daz
Acko
UK
Hi Daz & welcome
Have you disabled Power Management this can have the effect of re-booting the system if left on.
Acko
D
djwesty72
uk
thanks acko and oni for replying
acko is the power management in the bios or within windows ?
oni what is the thermal option and how can i disable it ?
thanks again 4 any help
daz
muthusami
india
hi
i have the same problem.
Did you get any solution?. if yes please post it. i wanted it
regards
muthu
Mhypertext
U guys are wanting more mhz out of the cpu
if so u need more volts to other wise it will reboot at randum
