- May 22, 2013
Ok guys so these are the 2 I'm choosing between.
Which do you think would be better for gaming?
Also, do you see anything that would cause bottlenecking for me? Something that is to low tier compared to the rest?
Any comments are appreciated! Thank you very much.
First PC:
Intel Z77 Core i5 Configurator
Processor ( Intel® Core™ i5-3570K Processor (4x 3.40GHz/6MB L3 Cache) - Intel Core i5-3570K )
Processor Cooling ( Liquid CPU Cooling System [Intel] - ARC Dual Silent High Performance Fan Upgrade (Push-Pull Airflow) )
Memory ( 8 GB [4 GB X2] DDR3-1600 Memory Module - G.Skill Ripjaws X )
Video Card ( AMD Radeon HD 7970 - 3GB - Single Card )
Motherboard ( Gigabyte GA-Z77-HD3 -- 4x USB 3.0 )
Power Supply ( 650 Watt - Corsair CMPSU-650TXV2 - Free Upgrade to 750 Watt Corsair CMPSU-750TXV2 ($20 Savings) )
Primary Hard Drive ( 1 TB HARD DRIVE -- 32M Cache, 7200 RPM, 6.0Gb/s - Dual 1TB Drives (2TB Capacity) - RAID 0 High Performance )
Optical Drive ( [12X Blu-Ray] LG BLU-RAY Reader, DVD±R/±RW Burner
Sound Card ( 3D Premium Surround Sound Onboard )
Network Card ( Onboard LAN Network (Gb or 10/100) )
Operating System ( Microsoft Windows 7 Home Premium + Office Starter 2010 (Includes basic versions of Word and Excel) - 64-Bit )
Second PC:
Cyberpower Z77
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive
CPU: Intel® Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 (All Venom OC Certified)
FAN HDD: Vigor iSURF II Hard Disk Drive Cooling System [+21] (1 x System)
FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Dual Standard 120MM Fans
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer [+10] (BLACK COLOR)
HDD: 256GB SanDisk SATA III 6.0Gb/s SSD - 490MB/s Read & 350MB/s Write [+88] (Single Drive)
HDD2: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD [+85] (Single Drive)
IUSB: Built-in USB 2.0 Ports
MEMORY: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
MOTHERBOARD: * [CrossFireX] GIGABYTE GA-Z77-HD3 Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Ultra Durable 4 Classic, 7.1 HD Audio, GbLAN, 2x Gen3 PCIe x16, 2x PCIe x1 & 2 PCI (Extreme OC Certified)
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft® Windows 7 Home Premium [+104] (64-bit Edition)
OVERCLOCK: Extreme OC (Extreme Overclock 20% or more)
POWERSUPPLY: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready [+20]
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: AMD Radeon HD 7970 3GB 16X PCIe 3.0 Video Card [+364]
If you see anything thats missing or doesn't match well with other parts, feel free to let me know.
I am leaning towards the second build as I get a Solid state drive and 1TB data drive (which Im thinking is just a storage drive correct? I will get the speed from SSD but the storage from HDD…(?))
Both have the Radeon HD 7970 which is making me drool, because I built these here instead of getting an alienware I'm getting the 7970 instead of Geforce GTX 660 for the same price.
Final note, I went with i5 processor because from what I've read it seems better than an i7 for gaming, or at least the difference between them is negligible. Any suggestions? (Please don't tell me to build it myself, I am not willing to do that, I want something that comes to my door that I can plug in and play. Thanks!
First PC:
Second PC:
Cyberpower Z77
