- Jul 23, 2013
- Houston, TX
All,
I wasn't sure where to post this, but i'm hoping someone can help me out.
I walked into my office today, pressed the power button on my PC and it won't post. The last time i used it was yesterday evening. When i shut it down it said "update then shut down" and i clicked it. Then left the house and went to dinner and thought nothing of it.
When i pressed the power button on the case, it turned on, then turned off, then turned back on, then turned off, then turned back on and stayed on however it won't post. No beep, no start up screen, nothing.
Also, i should note that the CPU PWR light is illuminated orange the entire time. I also have no additional LEDs lighting up.
I tested the power supply with the CoolMax PS-228 LCD power supply tester and everything showed up what seemed to be normal. However, i did test it a few times and it would flash "HH" and sound an alarm on the PG voltage reading. But it wouldn't do this all the time, only a few times and the rest it would read somewhere near 400ms.
My hardware is as follows:
Asus ROG STRIX Z270E
Core i5 7600K
16GB Corsair Vengeance LPX DDR4 3000
Corsair RMx 750X PSU
Asus ROX STRIX 1070
The full build is in my signature..
I've tried to boot with the GPU disconnected and removed, i've tried to boot with no ram sticks, 1 ram stick, and both ram sticks. I've checked the cmos battery and it's reading 3.15v with a voltmeter. I've left the CMOS battery removed to clear the cmos. I haven't tried to clear the cmos yet though via a jumper yet as i can't find a jumper. I've unplugged all SATA cables, and still nothing. No post.
I have a feeling it's the PSU due to the way it was acting when i first turned it on however the PSU tester seemed to show no issue? Could the PSU have taken out my motherboard and/or cpu?
or could it simply just be a bad power supply?
Please let me know your thoughts. I'm hoping it's just the PSU and i'm leaning that way due to no error LED's on the motherboard as well as its behavior when i tried to turn it on. I just recently built this PC only two years ago so i'm definitely hoping it's not the motherboard or CPU, yet.
Thanks!
Aaron
Core i5 7600K
Asus ROX STRIX 1070
Thanks!
Aaron
