hi. dont know if this thread is the same as this one, http://www.overclockers.com/forums/showthread.php?t=709955. so i just post a new one.
been posting the same problem at other site but no answer yet. so i try my luck here
i just bought amd radeon r7 240 2gb ddr3. at first i want to buy the nvidia geforce gt 630 2gb ddr3. i was told that the graphic card didnt fit my pc because of my pc small size. my pc is acer aspire x3995.
the technician insert the graphic card and my pc wont boot. no display with 4 beep. no solution so brought home the pc and google/check what causes the 4 beep.
4 beep mean something wrong with the ram. my pc have 2 2gb ram slot, altogether 4gb. so i removed the front 2gb slot and the pc turn pc start normally. i guess the removed ram is broken. now my pc hav only 2gb ram.
i insert the graphic card, restart and install the driver cd. it says please install vga card. i assume i didnt insert the graphic card firmly. when i successfully insert the graphic card, my pc wont start. not even 1 beep. cpu and graphic card fan spinning. monitor light is orange, no display. i removed the graphic card again and my pc start normally.
so whats wrong with my pc? is it because of my pc only have 2gb ram or my motherboard is not compatible with the graphic card? or anything else? from the post i came across earlier, should i disable or uninstall the intel hd graphic? i dont know much about bios.
thanks
thanks
