pc3500 on kt333 plus
xace
Daytona, FL
does anyone know if the kt333 plus will let pc3500 ram work in it?
i know that sometimes the mobo will take faster ram then it says it can.
Paradoxmaker
Ft Worth, TX
from the soyo website
Memory Speed/CPU FSB Support Matrix for AMD boards
This chart only applies to the following boards:
KT400 Dragon Ultra(Black/Platinum)
KT400 Dragon Lite!
KT333 Dragon Plus! Memory Speed/CPU FSB Support
CPU FSB DDR266 DDR333 DDR400
200MHz Yes Yes No
266MHz Yes Yes Yes*
333MHz No Yes yes**
* The memory will run synchronous with the CPU front side bus if 333MHz CPU is used.
* For a list of compatible memory for this board you can visit article S1073.
The chart shown doesn't say DDR 3500 is compatible but the tec article s1073 does list 2 brands of compatible memory.
Hope this helps.
