PCI bus transfer speed
ninthebin
Liverpool, UK
I have thought that myself...I dunno really, I would like to think they each get its own BUS rather than trying to hog one...
does anyone with pci network card sound card gfx card etc notice a distinct speed increase when taking everything out but the gfx card? if the answer is no, I suppose they are all seperate :|
hassmh
SE PA, USA
It is 132MB/s for the entire bus. A lot of server/workstation boards (dualies and up) have multiple busses (as well as faster ones), I don't think any desktop boards do, though.
macklin01
Computational Oncologist / Biomathematician / Mode
Bloomington, IN
Agreed, IDE master and slave share the speed on each channel. But as I understood it, each of the following were independent:
1) IDE0 (master and slave share)
2) IDE1 (master and slave share)
3) PCI (all slots share)
4) AGP
Is that right? Thanks! -- Paul
moorcito
Chicago, IL
yeah, that's what I meant. I though about adding the stuff about the channels but decided against it. Sorry about that
Henry Rollins II
Henry Rollins II
The North Pole
4) AGP
Im not a 100% sure about this, but I think that the IDE controller is a pci device. If it shares bandwidth with the pci slots also I dont know.
macklin01
Bloomington, IN
Good question -- that's what I wondered, too. I know that they share the same clock speed and divider. (eg., on my board, I have a 1/4 divider, so at my current FSB , they're both running at 37.25 MHz.) But whether or not they share bandwidth is something I'm not sure of.
I do know that the two IDE channels are independent of one another. (This is why they recommend putting your CDRW and HDD on separate channels, for higher transfer rates.)
If somebody could help, I'd certainly appreciate that! ;) -- Paul
macklin01
Bloomington, IN
Thanks! (And BTW, welcome to the forums! :sn: )
The strange thing about that, then, is that one of the the best ways to improve disk I/O may well be to move your video card to the AGP bus. -- Paul
ninthebin
Liverpool, UK
so if you have a ata166 hdd (even thought they never get that high anyway) but its a lie as it cant get higher than 133MB/s unless you have a better PCI standard?
theotherphil
England, Near Europe
The majority of high performance GFX cards sold nowadays are AGP anyway so this isn't a problem. The lower spec gfx cards won't push the PCI bus much. What will though is a couple of WD Special Editions in a RAID0 array....there's ~90Mb/s used straight away on a sustained transfer. If you do any sort of video encoding using dedicated Video hardware and a RAID array than things can get crowded :eek:.
macklin01
Bloomington, IN
That's right. You can never have higher transfer rates on the PCI / IDE bus than 133 MB/s. In reality, though, this isn't what's holding up disk I/O; it's the disks themselves, since they can never handle sustained transfer much above 70-90 MB/s on some of the fastest, fastest SCSI drives. -- Paul
macklin01
Bloomington, IN
Good points again! :) But ah, what a pleasant form of PCI bus crowding!!! :D
Actually, the one that occurs to me, then, is a 100 MB/s LAN transfer. Say you're transferring data over a network from a fast drive to a fast drive, one of the transfer rates is gonna' get clobbered .... Interesting. I guess PCI-X will be a good thing someday! ;) -- Paul
theotherphil
On a single SCSI drive maybe...the Cheetah X15.3 gives close to 70Mb/s :eek:. Get a couple of those babies RAID'ed and you can easily saturate a 33mhz/32bit PCI bus. I am running a couple of Atlas 10K III's in a RAID0 array and get pretty decent performance (see below). If I had a normal uni-processor machine (that only has a 33/32 bus) and also had a few other high I/O cards, I'd be in trouble.
