- Oct 26, 2001
- Mainz, Germany
I got a Abit ST-6 non-raid Board with a Cely [email protected] on it. The system works absolut stabil for a couple of months now without any problems at all. But what I don't understand is, that it only works setting PCI divider to 3:3:1, which means that FSB is on 139, PCI on 46,3 (!!!) and AGP on 92,67 (!!!). When I change the divider to 4:4:1 or even 4:3:1 the system won't boot at all. I think PCI-divices working at 46,3 MHz are nearly impossible. So I tried to test my PCI-ethernet-adapter in my secondary system, where it was unable to work, if the PCI frequency exceeded 40MHz. Also my GeForce 3 can't handle AGP frequencys in the second system beyond 85MHz.
I did check all jumper settings at the ST-6 and they all were in default position, as mentioned in the manual.
If I set my FSB beyond 140 the system will boot into windows, but within one minute harddrive errors occur.
I'm already out of ideas, so do you have any suggestions ?
Also does somebody know a good system tool, showing PCI and AGP frequencys under Windows ? (Other than SiSoft)
Thanks for help.
Thanks for help.
