It's weird making a first post. You see noobs being flamed all the time for not looking up their question better, and in all honesty, the answer is most certainly locked in the pages of one of these internet forums, but after running in circles for the last 6 months, I am offering up a sacrifice to the computer gods and laying myself at the mercy of the internets.
Angels and ministers of grace, defend us.
My question is really, How the christ does my motherboard work, what's the difference in Throughput speeds for a SATA 3 intel controller vs the two marvell 6Gbps SATA controllers, and why is there so much bs on the internet about PCI express Solid State Drives sometimes performing slower than a SATA 3... something..
http://www.overclockers.com/forums/showthread.php/750073-Benefits-of-PCI-E-SSD-over-SATA-III
Posts like that make me rethink building my own computer. I wanted something fast, something that could open a program in a couple of heartbeats.. instead of the grinding wait I'm used to. I have ADHD, and every time I have to sit and wait on an operation on this computer, like opening a new map or something, the waiting gives my wretched little brain the chance to get bored and wander off. I don't want something that scorches every benchmark, just something that can open a spreadsheet in one click. Apparently it takes becoming an enthusiast to get a chip and system to perform at acceptable speeds. Fine.
So I read, everything, and wanted to be informed before I bought. I eventually settled on the Asus P6X58D-E motherboard. I know I wanted the ability to change the RAM timings, and maybe overclock, so I got the 950 Bloomfield to stick in it. Unlocked processor, and a board that allowed you to take the RAM to 2000 if you wanted. Cool beans.
I had a 500GB seagate drive, and when I originally built the machine in 2011, I bought the Intel X-25M 120GB SSD. I don't know exactly what all the cache sizes mean, but in reading on the internet, it just sounded like the intel controllers were more compatible. I have no idea though.
It was lightning fast, and I used a ASUS ENGTX560 DCII OC/2DI/1GD5 GeForce GTX 560 (Fermi) 1GB 256-Bit GDDR5 PCI Express 2.0 x16 Graphics Card to finish it off.
I installed the OS on the SSD, it was just set up in AHCI mode, plugged into one of the SATA 3 ports on the mobo, and the Seagate was plugged into one of the two marvell 6Gbps ports. I had all of my documents and pictures and game files on the seagate. I have had nothing but bad luck with HDDs. The only HDD I've bought in the last 5 years that's still working is a 500GB seagate external hard drive that's just used as a backup. I've had a 1.5TB, 1TB, 2TB, seagate and a 750 WD hard drive all crash, RMA'd... and their replacements gave SMART warnings not a month in. More RMA's and "refurbished" drives to replace my "brand new" drives from the store, and I just decided never to deal with HDDs again. You'd think one out of the nine drives they shipped me would be stable. I just don't have the money to keep buying drives that don't work, that their comapnies won't stand behind. I'm ahead by just flushing the bills down the toilet and saving the frustration of dealing with another RMA.
My personal theory is that the UPS guys are having too much fun with HDD's. Or, it could honestly just the bumpy truck ride being shipped across the country that makes the drives close to failure by the time all the shaking and bumping comes to an end at your doorstep?
At any rate, I'm in the market for a new hard drive, and while the Intel SSD is great, I ran AS SSD, and I'm getting read/write speeds around 250/100. I know that drives slow down as they fill up, and I know that SATA 3 has a limit of 300 Mpbs (37.5MB/s) and that a PCIe 2.0 SSD would operate closer to 2.0's 500 Mbps? Or are these numbers per lane, and you take the specs of the motherboard to figure out what the data rate would be?
I've read about some people having issues with SLI or Crossfire with using a PCIe 2.0 SSD and their graphics cards. Apparently some motherboards only support X number of total lanes in their PCI controller?? (I may be completely getting the terminology wrong).
The P6X58D-E lays out like this:
Intel Socket 1366
Intel X58 Chipset
6 x DIMM (Max. 24GB) DDR3 2000(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Triple Channel Memory Architecture
Corsair XMS3 DDR3 6x2GB @ 1600
3 x PCIe 2.0 x16 (x16, x8, x8 or x16, x16, x1)
1 x PCIe x1
2 x PCI
What does it mean x16, x8, x8 OR x16, x16, x1?
If you have 3 devices plugged into the PCIe slots, what do the numbers mean? The number of lanes per PCIe slot? Do these numbers only pertain to GPUs when trying to figure out SLI configurations? Or would there be any kind of bandwidth limitations if I had my GPU plugged into one PCIe 2.0 slot, and the Plextor 512 GB PCIe 2.0 SSD that I'm thinking of getting, plugged into the second PCIe 2.0 slot, with the third 2.0 slot left open?
Are there any bandwidth limitations on the motherboard if you add a PCI device to one of the other PCI slots
I go on newegg looking for a new hard drive, and it becomes the frickin manhattan project...
I look at OCZ's Revo Drive3 and they tout speeds of 1000 MB/s (which is 8000 Mbps?) Does it mean anything that Plextor won the Flash Memory Summit 2014 Best of Show, That's why I was looking at their drives, that and the reviews I found. They seem like they do it right..
I found *tons* of comments just like these on all of the other aftermarket PCIe SSD's:
Pros: Installs in systems with no fast sata slots
Cons: Real world performance is about 1/5th advertised speed. 300-350mb/s.
Over rules any other raid controllers in the bios. Rendering them unbootable
Incompatible with most motherboards
Other Thoughts: Get some reliable intel or Samsung ssds instead.
Am I wrong in thinking that quality matters? And installation expertise? In my mind, there's no way of knowing whether or not the reviewer knew what they were doing. Could they have been installing the SSD into a mobo that does the PCIe like x16, x8, x8, and had their GPU set up in the #1 slot, thereby clothes-lining the bandwidth on the controller for the SSD? Or does it not even work like that?
Or would a RAID0 with 4x 120GB SSD's plugged into the Intel SATA 3 controllers give better random read/write times? I can't imagine that SATA in a RAID would be faster than a PCIe 2.0 connection straight to the motherboard. But I don't know.
If someone could explain this all in english, I'd be greatly apperciative, because I don't know what to listen to.
Intel Socket 1366
Intel X58 Chipset
1 x PCIe x1
2 x PCI
