I know but for the most part they go together! The lower your idle temps the lower you load temps are gonna be. Atleast thats the case for me.
And besides the main reason I asked is cause if someone is using a pelt with a reservoir and is running some kind of idle program. It may lower there cpu temps as well as get the water to no warmer then room temp. So when they benchmark, the load temp would be lower untill the temps stabilezed. Which could be quit a while depending on how much water you have in the system.
Now for you Badger that wouldnt be the case, cause you have a closed loop system. But it still could take a few minutes for the temps to stabilize.
I guess it would be the same as turning your system on and checking the temps under load right after you were to start the system up. They would be much, much lower.
But all and all I guess it's not important.
