What about a grid-like bottom of the WB?
Lite holes or something so that the water can get direct contact with the pelt but still toe pressure is evenly placed across the pelt...
A side-effect would be increased turbulance and area!
And phoenixpinion, I had the same idea a while ago, but I also very soon understood that the two sides would cool/heat each other. So that does not work...
Now I have been thinking of something else!
ssjwizard mentioned that you need a coldplate to spread out the heat from the CPU. But what if you would use a shim instead to cool the entire processor and not only the core... could that lead to better OCing?
The point would be to decrease resistance within the package.
It's nothing I have been thinking about a lot, so I wouldn't be to surprised if the answer was rather simple
