- Nov 13, 2002
- c/o UIS, Kow Yai, Thailand
Hello everyone!
I'm a bit new at this, so please bear with me. This is the first time I've ever used the oc-forums.
I am a final-year IGCSE student (grade 10, for those people under the American system), studying for an IG in Design Technology: Design & Realisation in Bangkok, Thailand. I have decided to create a peltier-based drinks cooler as my project.
So this doesn't actually doesn't really have anything to do with computers, per se, so I hope I'm in the right place.
I intend to use a second-hand PSU, probably around 220 wats or less. It will power only the Peltier and a single fan for the heat sink. The casing I will make myself, probably using metal for the base (where the PSU and the Peltier will be), and plastic piping for the drinks-holder on top. This will be insulated with bubble-rap (don't know what its called in the US - its the packaging stuff that people always pop) (probably), and metal - possibly copper, to retain heat and insure that any spillage does not damage the Peltier or PSU. The casing will be coated with black wood for aesthetics.
What type of Peltier should I use? Will 220wats be enough? Is there anything I need to know about Peltiers before I start? What type of heatsink/fan should I use? Do I need a fan, or can I simply let the exhaust from the PSU cool the heatsink? Should I use thermal grease or thermal expoxy? I dont want any condensation ruining my Peltier and PSU, so is covering the PSU with a plastic bag (with holes cut to enable airflow) a good idea? Would covering the edges of the Peltier with thermal grease or epoxy stop condensation from destroying it (Thailand is very humid)?
Would I be able to simply flip a switch to reverse the currant and start heating my tea? I know that cooling of the hot side (the side not touching the cold drink) enables better cooling (of the drink), but how about for heating hot drinks? Would the fact of the heatsink on the (now cold side) impeed or accelerate the heat on the (now hot side) - the side now touching the (hot) tea? (Umm... I hope that made sense.)
I once read about a guy who did a similar thing, but his drinks cooler was actually built into his system. Stupidly, I lost the URL.
Thanks in advance for any help you can give me!
Daniel
Daniel
