- Apr 9, 2002
- Anchorage, AK
I've had a 172W pelt for about a year and, now I wanna use it. Here are the Specs. Got it from Danger Den
172W
Imax = 11.3 Amps
Qmax = 172 Watts
Vmax = 24.6 Volts
Delta Tmax = 69 (C)
Size = 40mm X 40mm X 3.2mm
What amperage would this draw at 12v, and how would it perform at 12v? I'd like to run it off my 480W Antec Truepower.
Gonna be cooling a 2.8Ghz P4, hopefully at 3.3Ghz or higher. 1.75vcore's the highest I'll go. I'm not looking for supercooling here. Maybe 25C at full load.
And about Sealing the socket. Will using Neoprene be enough? Or do I need silicone, dialectric grease and the whole nine yards?
Thanks in advance for any help you guru's might provide.
172W
Imax = 11.3 Amps
Qmax = 172 Watts
Vmax = 24.6 Volts
Delta Tmax = 69 (C)
