Peltier PSU Question
Hoot (Mar 20, 2001 06:13 p.m.):
I assume all three run off of 12V-13V?
Hoot
I don't know what the peltier runs off of, but every thing else does.
The peltier is located at dangerden.com
your pump will run on an ac line i believe. On the peltier and fans, give them their own PSU.
I figured id have to, my real problem is I don't know what kind of PSU to use for my Peltier, or how to set it up.
dunno260 (Mar 20, 2001 07:15 p.m.):
My goal is to do what DrRom did,
172 W Peltier PSU UNKNOWN ???
Water mostly DangerDen stuff,
Enheim 1250 Pump Cooling Cube w. 12mm Fan 2 80mm Fans for my raid setup
fan in front, fan in back
And THIS CASE!!!
Case Depot
That 172Watt is prolly comin from TE Dist. And theirs is 24V @ 11amps. 18V-24V power supply would be the best. You could run it at 12V but only gonna get about 1/2 performance ~86Watt. Check ebay for "24V powersupply". And the fan's if you got a 300Watt PSU just run'em on it don't worry about external :). Hope that helps.
-dasouthernocer
