Pentosin Vs. Zerex, Help!!!!!
Liquid_Cooled
San Jose, CA
which would be a better mixture? pentosin(blue antifreeze)/deionized water or Zerex/deionized water? I need a mixture that will protect from corrosion (copper/aluminum), kill bacteria/algae, and does NOT leave any residue or cloud up tubing. also, what ratio should i put the addataive in?
thegame
stillwater, mn
well for one dont use deionized water cause that will be bad in the long run. get distilled water, and use a 25% antifreeze 75% distilled water. umm i run the zerex right now, but the blue stuff will do the same thing. it just all depends on if you want blue water or a pinkish purple color.
