I got my Koolance case the other day and I cannot put that waterblock on. The clip is just too small to fit in my K7 Master. I even removd the screw from the clip but still cannot make it fit. Then I removed the CPU and installed the waterblock. There's barely no room for CPU between the socket and the waterblock. I applied too much force that I'm worried if I damaged the motherboard. I think the CPU is find since I had a shim.
If you bought Koolance case, did the CPU waterblock fit nicely? I'm afraid clip is too small.
Also, this is not a good quality case. There were scratches all over the surface of waterblocks and some of the screws were loose.
--BrianC
--BrianC
