Performance gain between 1.86 and 1.90
maxima88
Aside from increase temps, what will I gain if I increase my vcore from 1.86 to 1.90~1.95.
If you aren't experiencing any stability probs...........nothing :)
If there aren't any issues at the voltage you're running at, any increase is absolutely un-needed. If you are going to push her a little higher, then a bump in vcore may be neccesary to acheive stability.
if your going to overclock it as high as it will go. spend the extra time to find the sweet spot that give you the highest overclock. 1.92 is a good place to start.
well think of it this way when u say take a 1800 1.53 to 1.6 i have to increase the 1.75 to say 1.80 or 1.82 think of that as the 1.85 going to 1.92 ull geta 50 mhzor more increase
