Hey,
I have a variable on @_ , I need to pull it off, set another variable equal to it and then shove it back onto @_ again. Can anyone help me out? Thanks
Well the @_ only has a scope of the subroutine you are using, so you can't use it anywhere else. Which makes changing the value of it kind of pointless. But I am pretty sure that you can change it. Just set the value of the element from the @_ array to the new value. For example of you want to change the 2nd element it would be $_[1] = "New Value";
ok got that first question figured out...this next one is about scope
is there any way for me to reference a variable local to a subroutine?
For example:
sub {
my $foo;
can i reference $foo somewhere else somehow?
thanks
