Phase Change vs. Peltier
Voodoo Rufus
Powder Junkie Moderator
Bakersfield, CA
I'd like to know about the above topic in terms of cost, maintenance and performance. From what I currently know, it cost a lot to make a Pelt setup, but it is not nearly as power efficient as a phase change system, and performs about the same, compared to a boxed fridge setup like a Vapochill or Prometia.
Also, which is higher performance, the Prometia or the Vapochill PE? How about for future CPUs?
I think that Phase Change systems are more eficient and better. I am currently building a Phase change system and i didnt spend a penny. I go the compressor from a old fridge but in a very good condition. The most expensive part in my project will be the water block. I think that i will spend max about 70$ on the sistem. I expect the temperatures about -30 till -20C.
the prometia is the best out of the box phase cooler around. phase coolers can get far colder tempratures than any pelt setup ever could. if you plan on building it yourself iif you look around it can cost less to configure than a pelt setup but a bit more diffacult.
Warlord2 said:
phase change will get you far better temps thin any pelt will however is a pain to make if you are starting from scratch.
Hey it isnt so hard to start from scratch if u are a member of this forum and if u read the guides on the net. For example the guide from some great members of this board likessjwizard and Bowman. Their guides are THE BEST. If u read them u can 100% make a PHASE - CHANGE system.
haha yeah I know how to do everything, what I mean is you have to obtain curtain equipment like a nice mapp blow torch, braze rods, capillary, gauges, compressor, condensor, evaporator and thin you have to know how to put everything together with the braze rods and flare fittings etc...
with a pelt setup all you really need is a pelt, waterblock&coldplate and a good sourse of power.
not quite, a peltier im getting has a Dt of 100 C!!!!!!!(of course the amount of cooling requiered is massive) if you to keep the hot side at 27 c the cold side would be -73c (thats a big if)
I like all this discussion. The problem I have with Pelts is that the power supplies cost a lot, and the amount of power it takes to run a setup. You add a 226W pelt and if you leave the system on 24/7 the power adds up on the bill (esp in CA, where I am). I really am looking at a boxed phase change setup for my next machine in a couple years. How does the Prometia compare to a home made system? I have none of the tools you speak of, and my main priorities are silence and good cooling.
haha I forgot to mention phase change can even have a passive cooled condensor if its big enough (hopefully mine will be):D
omg I just went to get my fill hoses today and the guy said hes not even aloud to sell them to someone thats not licensed, needless to say he sold them to me anyways:D Man I swear california has to be the WORST place for dealing with phase change. Oh yea 134a freon isnt even aloud to be sold to anyone here without a license:eek: .
Isn't the "env friendly" fluid in the newest phase change boxes? Can't you use that for your homebuilt systems? How about flourinert? Is that cheap nowadays, and could it be used for a phase change system or standard block/pump/rad setup?
Mind posting a link to this pelt?
litghost said:
my bad its a 87 Dt but still, http://www.tetech.com/modules/multi-stage.shtml
50 dollors for the pelt, havent gotten yet, backordered, will post temps when running
its the TE-2-(127-127)-2.5 pelt
You might want to try to cancel your order if you are thinking of using that on a CPU. The Qmax on that pelt is only 31 Watts. It could be disastrous to try to use that on a CPU. It's probably won't even provide much if any cooling on a modern GPU.
too late, saw that too
who knows, wattage is an energy unit not an energy transfer unit
most of the equation on the front page are talking about standard pelts
this is a muiltistage pelt, also the wattage may be per pelt, and there are 2 pelts in the stack
still it will make a nice start for a compact water chiller
omg that would be a good way to get a gfx or chipset very cold, stack a couple of those and I wanna see what will happen:eek:
btw I just fired up my phase change unit for the first time every and its getting cold=] anyone know how long it takes for frost to start forming?
Umm, would you guys like to give me any more info about phase change before you go off on other topics? It seems that is the way to go.
you should check out my article on the home page its last months winner its the middle one by Darcy Viohl(thats me!!) its a great how to and explination of how phase cooling works
