- Jan 10, 2012
just to make it clear your running 1.25 on the cpu/nb with the cpu/nb at 2400
your not talking about the nb.
One last thing..
for all you phenom II users , can you guys remember your ambient temps while OCing your chips?
mine is around 27-30*C and i think thats the main reason i cant go further atm.
i've found you need to boost your nb speeds up to 2400-2600, the nb voltages, and the VDDA a bit to stabilize up over 3.8 (you might need to downclock your ram too... generally most of my issues over 3.8 are ram related, not voltage or heat, though both of those can get crazy too)... i've had mine prime95 stable at 4.0... and windows stable up to 4.2... but the voltages and temps make me nervous... and oddly i can't seem to get it stable no matter what the settings at 3.9
Just for reference, my 24/7 OC on my daily driver for roughly the last 3 years.
why run this into the ground just to get a worse rig?
a 6300 is not what i would consider an upgrade.
I have both and I'll take my 965 over any 6300 that i have seen results posted for.
If your looking to upgrade that will take a better board and an 8350 with water.
I was under the impression that each core is faster.
